13 degrees timing? And knocking is not so heavy? Impossible, are you using racing fuel 24-7? HEHEHEHEH.....Originally posted by ZeNeGeR@Feb 1 2005, 12:35
i have done mine my ignition timing now is 13 not so heavy anymore ... thank god.
original mivec ecu
Originally posted by 4G93MIVEC+Feb 1 2005, 13:59 -->
QUOTE (4G93MIVEC @ Feb 1 2005, 13:59 ) --QuoteBegin-ZeNeGeR
@Feb 1 2005, 12:35
original mivec ecu
13 degrees timing? And knocking is not so heavy? Impossible, are you using racing fuel 24-7? HEHEHEHEH..... Has the timing connector been shorted when you took the ignition reading? I still think it is impossible to hit even 5 degree base timing on a MIVEC 1.8 without knocking. Do you have difficulties in starting especially after a hard run when the engine is hot? 4G93MIVEC [/b][/quote] my previous setting is 16 degree. Original mivec run on 10 degree. no problem start engine bcos the fuel is not too heavy i shot only. Some of my friend using 1.8 has tried 18 degree the MAX, respond very good. |
wow thats sound great !! i would like to meet him then . But do u remember his car plate no ? wat exhaust he using those 304 zigen ? Maybe got hi cam inside. My friend mivec have hi cam also very loud when mivec kick in.Originally posted by Spoon)))@Feb 1 2005, 16:53
sorry to bump intou guys..just wanna ask all the mivec owners,do u know one satria gti (ori or not i dont know) got mivec machine inside..last saturday i saw this car tarik infront of projet wangsa maju n guess wat,the mivec sound was so loud same like vtec...then i saw the car again at federal highwah tonjol my car,then the guy tarik again and once again the mivec sound get thru my ears...
the car got cf hood..anyone with the info pls share wit me..mebbe can yam cha sometime..coz really admire his car la...
thanks :D
CF hood... HKs exhaust ..... HID lamp ... crystal head lamp .... black tinted mirror........Originally posted by Spoon)))@Feb 1 2005, 16:53
thanks :D
may i know whats the pro and cons regarding my GB?Originally posted by delphinium@Feb 1 2005, 15:34
jzhost, from the docs I have , it seems that your gearbox is from 1993 CA5A 4G93. dunno wat model is CA5A .. GSR perhaps. it has a final gear ration of 4.592 which I found strange since you mentioned ur rpm is at 3k at 110km/h while my gearbox final ratio is 3.752 oso running at 3,000 rpm at 110 km/h .. anyone care to share?
btw, jzhost I already sent the pdf file to your email.
hi delphinum,Originally posted by delphinium@Feb 1 2005, 09:00
looks like bro ken oso suffering from engine knocking. Mine is oso knocking heavily. Even at 1st gear when i release the clutch too much oso can get knocking. Is it common for rojak hybrid Mivec to get this knocking thingy?
I've tried to retard the timing a bit but the problem still persists. I suspect this is due to the Mivec ECU is mapped to 1.6 displacement. 1.8 block has bigger stroke / longer piston travelling distance. Dont know how this could contribute to knocking but I really think it has something to do with it.
DDgrey dude, r u using Mivec ECU or combination of ur stock ECU + Mivec controller? Do u experience any knocking / pinging?
Originally posted by Henryfong+Feb 1 2005, 19:38 -->
QUOTE (Henryfong @ Feb 1 2005, 19:38 ) --QuoteBegin-Spoon)))
@Feb 1 2005, 16:53
thanks :D
CF hood... HKs exhaust ..... HID lamp ... crystal head lamp .... black tinted mirror........ got many sticker beside door area ...... GTI original colour with white colour rims ???? give me more info pls !!!! maybe was my friend ...... [/b][/quote] yeah....gti original colour..donnu wat exhaust,white rims...the rear is higer then the front like rally style...got a lot of sticker at the door side....hid lamp...cf hood.. i think its a malay driver...do u know?? but one thing for sure..the mivec opened sound was damm loud...mebbe he tot i wanna test with him coz im driving eg that day..but unfortunately my car got clutch prob that day so im just slow down while he kept on speeding to the subang airport exit... really like to meet this guy... |
i currently using NGK Iriway 8 ...... very good in performance ...Originally posted by gibod_78@Feb 7 2005, 19:03
Ok wanna raise a question here..
sifus .. whats the best spark plug to use on mivec?..
