I will join open track day twice a year.... the next is my 4th trip, will be fall on 24-Oct-10..
i'm using stock 93sohc block+mivec 81mm piston + ACL Duraglide bearing....
VAFC + SITC that enough for 92 or 93 mivec eady.... our ex-mivec club member used these two toys to tuned out a 16xWhp and 18Kg-m 1.8mivec... can search the VID at youtube ..
It might be ur ignition timing problem... since u have rallyart chip + SITC tuning will causing too advance ignition timing induce the knocking problem?? But need to check with the tuner for the ignition setting ....
you know our fuel grade not good as japan RON100 fuel .....![]()
And also have other issue can cause the knocking problem ... too many carbon build inside the chamber; cooling system not enough; plug heat range; A/Fuel ratio lean, O2 sensor faulty; and low grade fuel ...."Heat" was the main reason to cause knocking..... try to search at google, u will get alot of info about it...
Just don't get knocking problem at WOT that safe la.....
Don't forget to upgrade your injector as well .....
and if change this lightweight racing flywheel can get how many HP ? :hmmmm:Dear all Shifu,
P.ease help me. I driving lancer 1.8turbo gdi, which is a 4g93t engine but got stupid gdi. I want change out the head so remove gdi and get mivec + turbo, I think many of you have done this mix before 4g93block + 4g92head. Should I do this or just look for gsr head .
. So that there is lesser part to change? Btw my car is using invecsII. I don't know if ecu got affect auto gear box or not? Can someone please help me.... Thank you very much. Got any good workshop in jb/kl who do good conversion to recommend?
thanks bro for infomation , now i'm already using 275cc injector and today i go second hand shop i saw the mivec racing flywheel , around 4.5kg - 5kg. dunno what brand , they come with japan exedy racing clutch 3 puck , exedy clutch cover and exedy clutch plate , but the 3 puck clutch carbon finish already , then the clutch plate still in very good condition.RM600 izzit the price reasonable? because i'm just change exedy 4 puck full set already , before my exedy 3 puck clutch still have many carbon but the clutch plate can't use.so i'm thinking now want to buy this set item or not :hmmmm: if i buy already i have 1 set 3 puck exedy racing clutch for spareand if change this lightweight racing flywheel can get how many HP ? :hmmmm:
\\\Sometime change to "over lightweight" racing flywheel will decrease the "hp" but good in respond....![]()
but how to say will decrease the HP? why no +HP ? or the power + to torque? i just know using lightweight racing flywheel when heading to slope (naik bukit) no good respond,right?:hmmmm:
...want to play mivec pulak....hehe...Want to ask,anybody here using hotbits 4-1 extractor for mivec?I plan to get one la if anybody here give a good feedback ...no nid hotbit la..stock mivec xtractor is the BEST wan!!
