Dear all, Help needed !!! The check engine light turns on when I hit 160 km/h at fourth gear. Why does this happen ??? The check engine light's constant, no blinking what so ever.
check sensor connection...of course it will not blinking...sumtimes the wire socket is unplug with sensor in the engine bay...or other wise, ur sensor already out. last time 1 of my sensor i forgot to plug, the exhaust sensor, then it will turn on when reach certain speed...u need to plug in all the sensor...
Anyway, as recommended, pull the code, and understand what the ecu trying to tell you.
At the same time, did you installed or tune your "lorry" before this happen?
Blue Little Lorry was my previous car - My blue EG with all-round white bodykit =)
I just had an engine transplant to my sv4.....the engine check light does not light up all the time. It does sometimes when I hit around 160 KM/H at 4th gear .
guys in need some help on choosing which and what kind of standalone that can help me reprogramme my setup...now im using standard evo3..currenty im going to install the 4g67 block for my evo3 engine...anyone can...
This Saturday 21st October 2006 (Deepavali) SIC will be having a morning session which will be from 9am till 12 noon. Just an info for track lovers.....:X-:
