Dear all, Help needed !!! The check engine light turns on when I hit 160 km/h at fourth gear. Why does this happen ??? The check engine light's constant, no blinking what so ever.
check sensor connection...of course it will not blinking...sumtimes the wire socket is unplug with sensor in the engine bay...or other wise, ur sensor already out. last time 1 of my sensor i forgot to plug, the exhaust sensor, then it will turn on when reach certain speed...u need to plug in all the sensor...
Anyway, as recommended, pull the code, and understand what the ecu trying to tell you.
At the same time, did you installed or tune your "lorry" before this happen?
Blue Little Lorry was my previous car - My blue EG with all-round white bodykit =)
I just had an engine transplant to my sv4.....the engine check light does not light up all the time. It does sometimes when I hit around 160 KM/H at 4th gear .
Well, last weekend, just had a detailing DIT with some great friends. Thanks to for their help and guidance, I manage to get a new pair of headlights without even needing to buy one.
