Now available for all Honda using Keihin Fuel Regulators.
For B Series, D Series, H Series & CKD Civics.
RM110 for:
- 1 Custom Keihin Adjustable FPR Unit (Swap with your OEM Keihin FPR)
- Industrial Quality Pressure Gauge (Separate Warranty Provided)
- Brass Gauge Socket
- Twin Ring Automotive Clamps
- T-Joint for Fuel Hose tap-in
- 8mm 150PSI Fuel Hose
- Installation & Initial Tune Up
- 1 year warranty against A-FPR malfuction
Takes 20 minutes to install. Installation is based on appointment basis and one day advance booking. Installation will be done at buyer's preferred location anywhere within Klang Valley known spot.
Functionality:
- The modded A-FPR will be able to reduce fuel pressure below OEM standard level and can max out on the maximum pressure deliverable by your fuel pump.
- Fully serviceable internals, can change spring anytime for different rate of pressure
Reliability?
you trust Keihin? of course you do. OEM FPR are built to last, my A-FPR mods improvise on this existing quality and uses the original diaphgram.
Call/SMS me at 012-2407780 if you are genuinely interested. TQ
http://www.zerotohundred.com/forums/uploads/post-8-1106168323.jpg
http://www.zerotohundred.com/forums/uploads/post-8-1106168268.jpg
http://www.zerotohundred.com/forums/uploads/post-8-1105377928.jpg
RM110 for:
Functionality:
Reliability?
