- Joined
- Oct 8, 2004
- Messages
- 19
- Points
- 3,001
Originally posted by EFN@Mar 22 2005, 10:20
artnet:
Yes I am from Sarawak. But I rarely travel back home nowadays. Probably once in two years.
aEROz:
Hahaha that's not my own workshop la fren. Still paying tools rental but at least the taukey is very cooperative this time.
Ok so when you disconnect the vacuum hose off the A-FPR and the gauge shows vibrating/fluctuating pressure, I am almost 100% sure you have fuel pump issues. Before you throw away the bugger it is a good idea to remove the "penapis" attached to the fuel pump and run without it for a while to see if it eliminate the problem. Good luck there.
[snapback]829757[/snapback]
Hi EFN,
Any direct negative impact if we take out the fuel filter, beside possible dirty fuel ?
Thanks
