spring wira
zulhelme
just want ask... can or not wira 1.3 use spring sport wira 1.5 or 1.6.. pls help...
can bro....if using wira 1.6, slightly abit stiff....
bro... adding to above,
pls advice if stock car, wira 1.5 can use waja 1.6 stock spring for front? rear? or both?
reason for asking is, each time the wira going over bump, sure kena below (even slow slow also same) dun mention some aunties drive wira like those equestrian-horse-jumping-over-the-fence-of-bars style.. see also scare..
1.5 n 1.3 wira are the same, but 1.6 n 1.8 same, but cannot mix all, for rear all the same, only front is different in size of spring n abs..
the 1.6/1.8 spring diameter is different (bigger) so need to change the absorbers as well...if not the springs can't sit in the absorber cup of 1.3/1.5 which is slightly smaller....
