skywalker,...
This map sensor for what purpose? to control which section of the engine? Is it the air flow ratio?
In second pic, small black round with 2 tube on it? For what purpose? vacuum ka?
TQ.![]()
map sensor is to detects ur manifold pressure and send the signals to ur ECU
dat small black round thing with 2 tube connected to it should be ur oem ficd....
why u wanna adjust ur a/c on idle rpm??... not happy with it??...skywalker,...bro.
This oem ficd not adjustable rite? not like the Toyota denso ficd which can adjust.
I got 1 toyata denso ficd with me. What should I do???
Add on the toyota ficd (oem still maintain) to engine or replace the oem ficd with toyota ficd? how to DIY to get better idle when air-con compressor kick in.
Pls,... advice!![]()
if ur idling is ok..thne dun need to change it...
if ur rpm going up n down,up n down..then only u instal the toyota ficd.
the ficd easy to install only..2 wires and 2 hoses..u can try to instal.if its solved..then kawtim, if it stil d same.remove it lo
u near to zoo negara area o not? my mech is pro wit proton... :)
huakenny,..
bro, no wow.... I staying in PJ SS2 area.
NVM lar,... I can go over there mah. not far to me, cos I may use MRR2 or Cheras way to there also.
Mind give more information such as name of PIC, contact number, & location map.
I give a try see can solve my problem not..... but sunday open not?
Thanks.![]()
! who can help me!!!!!!!!!!!!!!!!!!!!!!!!where the workshop can help me repair!!!!!!!!!!!!!!!!!!!!!!
