What are these devices for???
viostar
Hello guys,...
Pls see picture below, what are these devices for & what is their purpose?
Pictures taken from P/Wira 4G13.:wavey:
skywalker,...
This map sensor for what purpose? to control which section of the engine? Is it the air flow ratio?
In second pic, small black round with 2 tube on it? For what purpose? vacuum ka?
TQ.:adore:
dat small black round thing with 2 tube connected to it should be ur oem ficd....
huakenny,...
Finally,... we meet again brother. Thank you for the explanation.
2nd pic is the oem FICD, pls have a look..... my car already 10yrs... this device still ok ka? need to change not? scare not functioning well leh? but this device seldon "kong" 1 right?
Any advice ... pls?
ar... :cheers: thanks again for the VS+ground cable & it is doing well leh.:congrats:
map sensor is to detects ur manifold pressure and send the signals to ur ECU
Bump: skywalker,...bro.
This oem ficd not adjustable rite? not like the Toyota denso ficd which can adjust.
I got 1 toyata denso ficd with me. What should I do???
Add on the toyota ficd (oem still maintain) to engine or replace the oem ficd with toyota ficd? how to DIY to get better idle when air-con compressor kick in.
Pls,... advice!:itsme:
skywalker,...bro.
why u wanna adjust ur a/c on idle rpm??... not happy with it??...
if ur idling is ok..thne dun need to change it...
if ur rpm going up n down,up n down..then only u instal the toyota ficd.
skywalker,...
emm... yes. not happy cos not stable some time ok some time not. This cos during a/c compressor kick in.
ori a/c compressor small unit. But last time "kong liao" than changed recond a/c compressor big unit not sample as previous one.
So, how huh.... any idea ke.:sleep:
Bump: huakenny,..
Should I change oem ficd? replace a new oem ficd to see further result?
Or it might be the mechanical issue ne...? cos khguan said usually is mechanical issue wow.
Any idea, pls advice.
:adore:
the ficd easy to install only..2 wires and 2 hoses..u can try to instal.if its solved..then kawtim, if it stil d same.remove it lo
bro,..
Actually, before this. I tested edi, he... he... kenny u never see it meh. during the time u helped installed the VS+ground cable the toyota ficd is there liao lo.
result was still the same during a/c compressor kick in the rpm will drop to 600 than went up again 800. I felt that the reaction when a/c kick in the ficd running slow but some time ok some time not.
I also dunno what to try on liao lor. That's why I got toyota ficd lor.
But when I tested the toyota ficd, the oem ficd I never take it off & remain untouch. Using both ficd on same time wow? it may give any bad effect or not?
Any advice... TQ:adore:
huakenny,..
bro, no wow.... I staying in PJ SS2 area.
NVM lar,... I can go over there mah. not far to me, cos I may use MRR2 or Cheras way to there also.
Mind give more information such as name of PIC, contact number, & location map.
I give a try see can solve my problem not..... but sunday open not?
Thanks.:adore:
u near to zoo negara area o not? my mech is pro wit proton... :)
huakenny,..
Thanks.:adore:
u boss ma..u wan sunday open..i tel him, he sure open one...lol
