About the adjustable .
Hi Kendiriwan and Izzo,
Thanks for the sharing.
Need some opinion again, how does my current adjustable suspension compare to installing a sport absorber combine with sport spring?
Will the effect be stiff and jumpy like my current adjustable?
Have you heard about a brand of performance sport absorber and sport spring call Proride?
Hope you could share again.
Thanks.
Thanks.
Izso la.. not Izzo
And yes to both questions.
Sport springs are shorter and stiffer, paired with short stroke sports absorbers means lesser travel and faster rebound, which usually result in bumpier road handling. The question is how much bumpier compared to hi/lo suspension.
Proride, APM Performax, GAB, SACHS, Eibach, Improve, etc all will result in bumpier ride compared to stock.
If you want cornering ability without sacrificing too much comfort - get bigger, lightweight rims and run on low profile and wider tyres. Then beef up the antiroll bars (front and back). That'll do wonders for your cornering already. It'll hurt the comfort level a little but not as much as adjustable suspension.
Having said that I don't know if they make fat antiroll bars for the Livina.
That's why previously I changed to sports absorbers from GAB, in order not to sacrifice too much comfort, I maintain the stock springs.
If not it will be bumpier than before. This setup can be done. Handling surely better than stock but then at least u still have some comfort in it.
Livina not meant to be mod that excessively.....:biggrin:
Maybe the Sylphy bars can masuk. Rear 19mm ARB, undercarriage 4-pt bar and change the Livina front ARB to Sylphy one. Hehehehehhe
---------- Post added at 01:36 PM ---------- 6 hour anti-bump limit - Previous post was at 01:34 PM ----------
Pros and cons. Short stroke sports absorbers with full length springs means the absorbers or springs will be very likely worn faster. Or was it the other way around. Either way I doubt you'll get too much performance improvement compared to full swap.
Ajustables hi/lo/soft/hard with 30+ damper settings with bodyshift laaaaaaaaaa.. everything else is inferior.
Yup not much. Anyway the absorbers became soft after 1 1/2 years. So almost can say back to square one.
My fully adjustable all the while pretty stiff ride. Today ferry 5 cartons of lube to my mechanic, the car damn stable and nice ride......hahahahahahaha:biggrin:
Your kids and wife also never complain. That's a good sign!
Eh when you gonna fix that leaky pipe la? Exhaust so loud it's beyond ahbeng levels liao
Got complain, that is why they use the Tiggo and Hyundai more.
But with 4 of us in the VR the ride not too bad......hahahahha
Actually the muffler exhaust also loud mah! But anyway, saw my mechanic yesterday, told him I am sending in on Monday. The problem is actually the exhaust manifold bolt has broken off. Probably need to take the head out to machine.....:bawling:
Means u shud add 2 more inflated spare tyres in the boot. :rofl:
Hi Izso and all Guru,
Thanks for your advise again.
The Antiroll Bar i'm using is 18mm and is the biggest.
Need your help to give me some of your opinion again.
I'm thinking about a few combination
1. Stock spring with sport absorber like GAB, tien and so on, will i get less jumpy and handling will improve and at the same time the comfort still remain in a reasonable manner?
2. Sport spring with normal gas absorber, will this also improve the handling and at the same time comfort will not sacrifice too much?
3. Base on what i have on the adjustable SSR300, if i adjust it higher and will the bumpy sensation be minimize to a reasonable comfort rate and handling also still as expected?
Please advise on my above idea.
Thanks.
Thanks.
1. Any sports absorber will have a fast rebound and since it's short stroke, don't expect any sort of comfort. Probably will be softer than your hi/lo but still hard. And paired with normal springs will probably shorten the lifespan of the absorber.
2. This might work, but probably will shorten the lifespan of the absorber as well. I don't know. I've been in my friends APM Performax springs + stock absorbers before, it's still bumping and too low until scraping everything. I'm used to bumpy so to me this is kinda ok. But it was similar feel to my hi/lo/soft/hard on medium hard settings.
3. Probably not. Suggest you consider a softer spring.
Thanks.
You can adjust the spring height to improve comfort or handling. ! A 10mm lift will give you better comfort, less bumpy. Try it.
I lifted mine 20mm and it ran over rough uneven road like nothing, very comfort. But hard driving/cornering suffered, wife complained about boat effects. So I dropped back.:banghead:
Thanks.
To me, any mod to your original suspension sure bound to be more bumpy.
As for the high/lo suspension where you adjust the springs for it to go high/lo, setting them low is more comfy. Set them high is compressing the springs therefore more bumpy.
---------- Post added at 08:59 AM ---------- 6 hour anti-bump limit - Previous post was at 08:59 AM ----------
Mine was the other way around....:hmmmm:
So bro if i were to install APM springs, but using SACHS absorbers, anything I need to take note on the setting?
Buy a used welding machine and DIY!
