Item:ARK Design Rev Shift Timer
Price: RM430
Location: Tmn Connaught Giant Ground Floor, Balakong, Ampang Tesco, Subang, PJ.
Deal Method: COD, Self Collect or Posting
Payment method: Maybank2u,Credit Card,Cash Term
For other performance part please "Click Here" or Log on coozauto.blogspot.com
Product Description:
Rev Shift Timer also has these following displays and functions:
Post drive idling
Auto mode- this calculates the engine status just before post drive idling, so the idle time will be the most ideal time for the engine, ensuring no unnecessary fuel is consumed.Manual Mode- post drive idling time will be performed according to the default setting or setting made by the driver.
Rev/shift timing display RPM can be detected and displayed using either alternator pulse (simply through power connection) or alternatively directly from the ECU rev signal. The lamp also flashes to remind the driver to shift up when a specific rev has been set.
The simple A/F reading is displayed via the zirconia type O2 sensor signal from the ECU. According to the A/F reading, the full color LED changes to inform the driver of engine status and fuel consumption.
Battery voltage display
The battery level and charging status can be displayed.
Hand Brake Safety
Prevents engine from running in post drive idle mode unless handbrake is engaged thus increasing safety and security.
Large LED display for easy identification
The large LED display can easily be seen, even within a disruptive environment. For vehicles without zirconia O2 sensor or where O2 sensor deterioration has occurred, some of the displays and/or functions may not operate correctly. Some vehicles may not be able display accurate rev, in such case, connection to rev signal line (ECU) may solve this issue.
Price: RM430
Post drive idling
Hand Brake Safety
