if ur using ae92 knuckles, then the se limited absorber can fit....
the thing is, u must use the LE top mount on the absorber...
since i'm using ae101 absorbers...
i just installed the absorber...unfortunately only front abs can be used..rear cant due to a bit long on the drum holder( i dont know whats the name of the 2 hole of the bottom side of the abs)...so what need to be done...btw how much is the cost of set of driveshaft..easy to find or not...thanks sifu..
Bro..help Me Plss....
I Just Bought A Blacktop Halfcut For My Ae101.
But My Ecu Have A Problem....how??
Is That Any Way To Claim Back???
Or Must I Buy A New One???
How Abaut The Cost???
Hi all.I just installed a cheap 2 way alarm at nearby acc shop.first time went there,after finished the installation there was no problem.later went there 2nd time to fix relay for trunk release and after that my ABS...
Hi! I don't really know what the heck the thing is called but it's made of rubber going from the shifter to the gearbox housing. Mine is crap already and it makes shifting gears a pain. If anyone can assist me in...
