WEBER or INJECTION ?
aren't weber carbs a real drinker on fuel? or maybe u gotta get a fine smooth tune to get a powerful yet fuel efficient car .. ?
khoyos said:
since all carb sifus (fstrader, cipan, jcn) posted their carb pics, let me show mine. but now not using carb anymore. now using injection. really miss the carb days...
i was wondering...
how do u go about getting ur carb into fuel injection? wat did u changed ? its equal to changing engine issit ?
nitrus, he was saying he miss d carb days when he had a carburated engine but now mr khoyos (da sifoooo) has switch side to injection already...
mine also using weber carb progresive webber...huhu
now planning to use dellorto twin carb drla 40..hhoho
oooo mr khoyos ...
a question, EFI reli alot faster than carb engine right?
if example carb and EFI mod the same thing, the EFI will still b faster... right?
[EDIT] : NO bashing of EFI/carb plz.
nitrus said:
oooo mr khoyos ...
hhhahaha.. but reli ar fred, so unfair la, EFI reli alot faster than carb engine right?
if example carb and EFI mod the same thing the EFI still faster... right? stupid la.
here we go again with all those comparison thingy.....
have u test all these mod?what mod?putting microcompressor?jet turbo?surbo?izzit the mod?...
r u comparing this based on ur theory?which book?author name?year?
izzit cool having lots of theory this and that?
and in the end..EFI user and carb user are fighting in this thread..
izzit this u looking for?
:shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo::shcokedcamo:
Pls discuss and contribute constructively.
If this is another one of those "VTEC vs Turbo" lame duck threads, this thread will be CLOSED indefinately.
PLEASE USE ABIT OF COMMON SENSE BEFORE POSTING.
wow, i din expect that kind of reply.. why so sensitive weih?
if im wrong then cakap je la .. dun have to come to this point. wat carb fight EFI shit pulak... i din even hav any negative intentions when i posted earlier. :Not_Impressed:
Cipan_supercas said:
have u test all these mod?what mod?putting microcompressor?jet turbo?surbo?izzit the mod?... izzit cool having lots of theory this and that?
i belum cakap aper also i kena tembak ady... cool ...
if u think carb n efi is same, good la. all i asked was a simple question. not trying to b cool with any of my theory becoz i have NONE. :Not_Impressed:
[EDIT] joeker : i was merely adhering n discussing on the thread's topic when i got blasted... guilty?
its not bout tembak man...
just sum of the words will contribute just like a "Vtec VS Turbo" thread... ..and it will never end.. :sad_smile:
no heart feelings...lets continue this thread..cheers.. :regular_smile:
sorry la cipan .. no i wud never want 2 start a VS thread .. so others, plz post with a open mind k? cheers...:regular_smile:
so can i rephrase my post earlier?
a stock carb 1.3, with a stock EFI 1.3 , drags ... how come the EFI faster? or it could be the driver's skills .. ?
plz NO BASHING replies ok?
If you put two same lausy drive the result will be injection tooo if both car still in stock OEM ..
The different is EFI giving you a combustion with different air fuel ratio at every stage of RPM..
And carburetor fuel system, giving you almost the same too, but not as efficient as EFI giving the AFR to the engine..
but when both car at at the peak of the RPM lets say at 6500RPM.. the consumption almost the same wheater it is EFI or Carburetor..
But EFI can be tune up without harming the AFR at below RPM3000..
because EFI it's a latest technology of Fuel System..
When comparing EFI to Carburetor like comparing Nokia 3310 where you can compose your ringtone with OLD MOTOROLA wear it's bigger than your Codeless Phone at home with mono flat tone.
so frankly speaking, in the end EFI is still faster than carb right?
n wat is AFR ?
The point here is not "faster" but efficiency.
Carburators and Electronic Fuel injection are devices to meter and regulate the amount of fuel.
I think its pointless to debate which system is more than able to do the job well.
AFR :air fuel ratio. rite?
EFI does a better job in supplying fuel to the combustion chamber.IMO
But one thing for sure, try using an EFI car to race with a Shelby (Carb) n see....Who win ?
EFI = Sunday Driver / Skilled Driver
CARB = Sunday driver / skilled Driver
See, not much difference la. Improving ur driving skills is a better idea! :shades_smile:
