wat fuel pump u all using on ur 20v eng..from hcut or buy new from performance shop..why my high rev like not enough fuel supply even already set to 35psi wif my fse..i think my fuel pump mau kong kuar..
did you mod an internal fuel pump into a carburator fuel tank? if so just instal a fuel surge tank will fix your prob. this is because as i know(my mech tell me one lar, when i change fuel tank), fuel tank for carb engine don't have that "bracket" inside the tank to hold the fuel in place when you do hard cornering, thats why when you corner fuel roll to one side and the pump isn't getting any petrol at all.Adeen said:i don't know what fuel pump i'm using.....i think half cut one.....
and is going through the same problem as ur 20v...
if my tank is filled with only rm20 of fuel....
when i take a corner at fast speeds, my car seems to die for awhile during the corner and will ignite back when i'm on the straights again....
how sad...:(
Heat shield with CAI for my Apexi . http://i3.photobucket.com/albums/y61/Ayok/HScwCAI.jpg
