Urgent Help Needed
huakenny
LB Performance
Kota Kinabalu
okay..juz now on the way go home...sudenly my cd palyer no sound oledi...CD Player is running...juz totally no sound
so reached home i checked my AMP..the AMP
Power' LED din ON..mean no electric reach amp izit?
wat is the possibility to cause my cd player no sound? din touch anything.....juz sudenly no sound....
HELP>>>>Urgent Urgent
check power cable for the amp .. maybe longar liao ...
check the power cable direct from battery one....
there should be a fuse protecting it.... check it
check your amp fuse
check all your cable if any loose
check your amp fuse
so wat come to ur mind? which is the main cause u think? AMp no power but HU got power.....
your HU and your amp tap power from the battery, but using different cable, so...check the power cable, and all the fuses.
next, check the remote cable which connect from HU to amp, which turn the amp on.
nothing to do with with RCA or speaker cable since the amp didn't on
Hope for the best, cable lose, middle, fuse blow, the worst amp internal problem. You have to check all the wiring and fuse. The HU is normally follow the stock wiring. Where got such a good installer will install your HU with laying new cable from battery?
if theres a demand there will be a supply, just add cash....
kenny for starters just check the fuses, on the amp, or before the amp, or the one after the battery.
Hi
Check the remote wire from hu to amp, maybe loose.
Check cables make sure all is secure.
Check fuse, make sure non is blown. (power cable fuse at amp, distribution block fuse and amp fuse
Use a multi tester, voltmeter or light bulb to
- Check amp power cable, make sure got power.
- Check remote power cable (HU to amp) make sure got power.
distribution block fuse normaly locate at where? amp n power fuse i know
Is your ICE high end one or low-middle end one? Or rather I ask how many amp you have? Did you check your connection, fuse already?
high-end or midle i not sure o......mohawk n kicker stuff wit alpine HU....One amp,one pre-amp....12" woofer....etc...rest i duno wat...not familiar wit those...
fuse i wil check later....
Like that ar, hard to help you. But as per sifus said ealier check all the componenets first. The distribution block is just like a fuse holder, it is 1 input then 2 or 3 outputs, you can see it easily when you open your bonet.
ok guys...problem SOLVED...
problem is caused by the power cable fuse located near battery..the fuse is ok but dunno y the elctric cant go thru...so juz buy one n replaced it...
now ok oledi..
THANKS :dancing2: :tee: :rock:
howiechoo said:
sometimes, fuse break cant be seen.
yes its true, happened to a friend before, real headache to find the problem.
that day my fuse blown..then i replace new one..but my AMP got Power LED on and also Protection LED on...lastly send in for repair..3 transistor kaput..but now it's okay lar..
the only problem is when i off the engine, got sound like short 'Boom'..and sometimes when i slow down the volume i still can hear my woofer 'berdengung'...ehehhehhe
wat happen eh?
