- Joined
- Sep 1, 2004
- Messages
- 1,024
- Points
- 5,136
speed,
patience my fren...my car has been in w'shop ever since last yr, only on da road jus for runnin in..other than tat now my microtech got problem,left my digi handset on da floor(buttons facing down)password was put on accidently..had to send back to aussie, now still waitin..so mayb goin in sepang wit stock ecu n boost only 1 bar...sigh...i'm definately goin..i think jamil(extremeleo) oso goin..not sure..
tezt,
wit standard internals u cant boost high, u gotta understand tat NA engines run on high compression..turbo is low..so honestly u cant boost high..mayb 0.6 will b ur highest..if u wanna boost high find pistons tat r almost da same size wit low compression or get slightly bigger(xtra cost of reborin ur block, n possibilities of moddin ur conrod)...thrs aot of things u gotta do..normally i u don hv a solid base ud b spenddin alot jus to turbo charge..
coz now from carb u gotta convert to EFI n u wanna turbo charge..alot of money thr..unless u alredi usin EFI then diff story..if i were u got for GTti or 4e..up to u...
tezt,
Have replaced complete float unit (brand new from Wing Hin) still...
