most of the cars are running slightly rich, this is to protect the engine itself.when the weather temp etc changed...the stock ecu still can compensate to the changes..
installing fuel map controller to the stock engine may saves you in the fuel consumption, but for engine protection wise. it may reduces.
ic , because ask b4 at tom's malaysia he say no need dyno tuned ......
who are want to install this can help ask to comfirm than let's us know here
thanks
Hi All Sifu,
i have something need to ask and know about our Airtrek subframe (front) & (rear).
Our front subframe if want to convert to EVO, version 7 to 9 is can fix, right? if only take the EVO lower arm to fix on...
Anyone know if a 18x8 +45 wheel will cause any problems with fitment? I'm running 17x8 now but don't know the offset. Should I run spacers? My concern is that the wheel might sit too far in and rub against something...
any altezza owner have the sound like krok krok krok ??
when i stop the car..then i tekan minyak lagi..got a sound "krokrkorkorkrokrok" dunno comes out from where..it seems like from console box..but i guess not...
