Spoonz said:yea..near the half mark...
but when it cross the half mark there must be a problem...
syakir,
I had recently service my radiator (double layer) and it cost me 60.
check for the water level in ur radiator oso...
if the water does not kering (when overheating) then ur radiator must be ok..
Spoonz said:what do you mean by water will kick back to reserve tank?
usually when overheating occur water in radiator will dry and so do water in reserve tank...
water in reserve tank acts as additional supply if the radiator needs more fluids to cold down the engine..
m_syakir_r said:i mean when overheat, the reserve tank is full of water seems like the pressure kick the water from radiator to reserve tank.
parimus said:lastime my car also like this.....when overheat, the reserve tank is full of water.
in my case, the 'water drain plug' is loose. i went to radiator shop to checked, they just seal with 'white sealent tape' like water sealent tape. after that ok. can DIY.
shiroitenshi said:My temp is okay middle on the afternoons, on the hot sun on the highway... but I need to top up the reserve tank almost every other day... Have tried looking for leakage, but cannot find any.. no water/coolant stains on floor when I leave my car overnight.
i suspect the radiator itself has a micro leak in the fins, and when driving, the flow of air causes the water to come out of the leak.
Aih.... considering other mods I'm planning, coolant costs is something I'll bear with until I have enough budget for a aluminium radiator.
c00lric said:Hi shiroitenshi,
I've facing da same prob as u r. So u suspect is the radiator that's causing da prob? is it by changing the radiator will solve da prob?
shiroitenshi said:Err.. that's normal-lah.. depending on how you drive.. on really hot weather, and you're running high revs.. sure high temp onelah! On highways, the heat from the road gets into your engine bay.. cannot avoid one lah!
Changing the radiator won't definitely solve your problem... so hold your horses if you think I suggest changing the radiator!...
I'm changing the radiator coz I'm a mod person.. when something is amiss, I tend to change it to a performance part, rather than the stock one.. it's just what I like..
For you, better check at the mechanic/friend/other forummers I think it's wiser to see what the other's suggest.
I'm not suggesting anything!!!
c00lric said:Hi Shiroitenshi,
Well, thnx. I've already sent 2 da mechanic for a check up. No sign of leakage or anything like that.
And just now i went 4 a hard drive (rev up to 4 ~4.5K RPM, not really hard i guess) and as i reached home, the water were spilling out as i drove to the front gate of my house. What could hav happened?
shiroitenshi said:Hmm.. I'm not too sure, but it's usually the sign of blockage, or like some people say, overheating..
My temp gauge is at da norm level and i did top up some water in the reservoir in da morning as water level has dropped to the low level marked in the water reservoir.
i even cant saw this car in Auto saloon 2009...
