clonexx said:Bro, u got pm
Bro,
Yup, I do have PM, so you can either comm via e-mail, here in ZTH or PM me any questions..Will try my best to assist you..
cheers
gerard
jinkl- said:hehe still waiting a kit for 63t :P
gerard said:Bro,
Shall reveal the figures by next week but only modest figures, so please do not expect very high hp figures ya.....
cheers
gerard
gerard said:Bro,
Thanks for the interest in our sc kit...The waja project would only commence sometime next year, it will require a different set-up, as the crank pulley is located on the left side of the engine bay. We will get the other models out first before getting work started on the waja...Keep in touch and do hang in there..
cheers
gerard
risyia said:Yo Gerard,
Had a minor problem a few days ago with your supercharger installation.
Found out that the hose clip for the fuel hose that attaches to the additional fuel injector has cut into the fuel hose and caused a fuel leak.
Only a simple problem that can be easily rectified but I thought I would bring it to your attention so all of them that have installed the supercharger could take note of this potential problem.
Regards
Shah
yewkongthoo said:Does this sc kit increase fuel consumption alot?
gerard said:bro,
Now, this question is a very interesting one!....Everyone wants power but not the fuel consumption that usually comes with it...We at Voltz Hybrid Development truely understands this matter and we do have a solution ..... As the supercharger unit could be switched on / off as and when you require, during this process when you do not run the sc unit (off mode) you will be running on a NA (improved version) map which is tuned strictly for fuel consumption saving....and a bit of power but without boost...
When you do run the supercharger unit (ON mode) you will then be running a seperate map that is tune for performance and power, therefore fuel consumption should not be an issue here, all will then be depended on how spirited you are....This comes completely tuned and is part of our sc kit...
Cheers
gerard
gerard said:bro,
Cheers
gerard
Poorman said:i just want to ask you regrading to my car. i am driving a 1.8 putra with production engine. that engine with metal gasket,cam pulley but don know whether got cam or not because i never open and check it.i have heard from some of mechanic that this engine may has 1.9 piston insides. besides that, it is definitely high compression compare to stock 1.8.my question is is it possible to bolt on supercharger to my engine?i really interested but i just worry it might give me a lot of hassle and need to change a lot of part.i looking forward to your reply.by the way, how much is the total packages for my 1.8 now?
yewkongthoo said:wow... that's really interesting, we can switch the sc on/off while the car is running? let say i am cruising on highway and suddenly decided to on/off it, i can do it right away?
speedking said:Gerard,
when Mivec SC kit will be ready?
waited so long already....haih... :(
really interested man....
anyway...good job on the SC kit.....
risyia said:Gerard,
Maybe you can look into one more issue, since the piggyback is programmed to run richer to allow for the installation of the supercharger.
Can you recommend any aftermarket device that can increase the ignition capability of the spark plugs to allow more complete combustion??
Bro,InitialD said:That is damn cool man!
