BTW...Originally posted by differ@Feb 20 2005, 03:18
THis incidentally is a good way to check your alternator. Start your car and once the engine runs, pull out the positive terminal of your car battery. If the engine dies, means your alternator is faulty and will need changing.
I might have well found out the problem...
This morning when i wanted to start my car it was dead...no sound on the ignition also when i turn the key...
so I open the front hood and check...to my surprise one of the terminal of the battery is missing its bolts and nut...and it was loose...so i adjusted it and use a wire to hold it up temporarily...
well...I turn the key and YES it started moving...
However...
differ u did say that once the engine started moving the alternator will take over it's job from the battery right??
and in my case let's say IF one of the terminal is loose and my engine went dead...the engine should still be running right since the job has been passed down to the alternator...
so I will try the technique as quoted by u and see what happens...
please confirm what i am saying is true??? :huh:
and i'm not rich and really can't afford...
