Skyline Gts-t and Gts4 difference
stormlcc
Guys need some help here...I'm trying to find a half cut of Gts-t to fit my A31 Cefiro, and I know that these two types of cars looks the same on the outside, any methods of identifying which is which? Thanks very much!!!
The GTS-4 is a 4WD, so you'll expect the halfcut to come with 4WD tranny and front propeller shaft and drive shaft.
Another thing you can do is look at the shassis number...
HCR32, KRCR32 is a RWD chassis
HNR32, NR32 is a 4WD chassis...
this way you don't have to climb underneath to check
U shud b able to see the front drive-shafts. Don't even try to 4wd yr A31.. it doesnt work..(diff chassis). Just 4 yr info
:D :D :D
