i drive Satria 1.6 GLi 97'...when it stop in idle mode...tempreture will rise to the red line.it not happen when i drive it.it is radiator problem?how much radiator?anyone know good machenic at alor setar?NEED HELP HERE....:cry_smile:
Yeah, try crazykid opinion/recommendations, it will helps. Coz sometimes when you dont service or replace the water in the radiator, the water pump got stain and it cant move or move slowly which not help reduce the temp.crazykid said:1.check your water pump, if you`ve never change your water pump.for goodness sake change it, you would be happy to see that the water pump is rusted and harder to spin compared to the new water pump.
2.change the radiator pipe if you need too.if the pipe is brittle change it ASAP for a good piece of mind.
3.service your radiator la bro...its not that expensive,But if you think that a new radiator is much more worth buying then yeah its your decision anyway.
4.i do agree with "craziqbal" it could be your fan that is defective
5.do check your radiator cap, just in case the rubber is weared off
