- Joined
- Oct 9, 2008
- Messages
- 107
- Points
- 5,018
Hi,
This is to share my bitter story of owning a Exora so that you know what is to be expected when you are planning to get a Exora for yourself.
After much serious consideration with other models in the same range, I bought my Exora M-Spec in May 2010, I am so regret now because the car will wobble/goyang when picking up speed from 2000RPM to 3000RPM since the first day I got the car, I have checked with other Exora owners, they do not have this problem.
I called the iCare line many times and after numerous visits and complaints to the Service Center(which they failed to fix the problem and told me it is the 'character' of the car), they sent someone directly from Proton technical department to sit in my Exora for me to show them the problem, they recognized this issue and told me the same problem also happened to their Saga model, but they are Not yet identify the solution to fix this problem. ETA for solution is not available.
I am so regret for making the decision to continue supporting Proton while I am able to afford a different brand, I should have bought the Nissan Grand Livina instead... sigh... :(
If anyone out there also facing similar issue with their Exora, I invite you to share your experience here so that other forumers are informed so as not to make the same mistakes like ours.
I wonder if anyone out here can advise on the...
