Perodua MYVI performance remap chip
1 year hardware warranty.If the chip no function can return the chip and change new one.We give you test,install this remap performance chip before buy it,if satisfied you can buy or if you not satisfied no need to buy.
all sounds good..
i collect money first..
hope to meet u soon..
how long to fix n remap?
hi, would like to know on your rechipping, are you able to do a chip for myvi with BOT?
Persona can but using piggyback technology.Remap still under development.
20 to 30 mins plus install n remap..?
my e-manage just leave it or take out?
or stil can use in future remap from new mod..
Hello,unfortunately we cant performance remap for myvi with BOT.The performance remap is only for NA myvi.
---------- Post added at 12:34 PM ---------- 6 hour anti-bump limit - Previous post was at 12:00 PM ----------
Better take out your emanage.No need to use emanage after install this performance remap chip.Emanage is piggyback technology which old technology.Only fool and trick map maf sensor and send to ecu to modified air fuel ratio and ignition timing(if emanage ultimate) and got 2-3 protocol before ecu can receive the signal and reprocess it and give little bit increase in bhp and torque .It less in stability,less in effectively and less consistent.In short word piggyback is not perfect performance ecu upgrade .
Performance remap chip is direct command no protocol and fully performance data upgrade just like stand alone ecu which latest technology in street or track performance.Its upgrade all the map data:
1.)Fuel (Air/Fuel Ratio)
2.) Cam angle (latest variable cam timing)
3.) Ignition timing
4)Other variable (Variable valve timing like VTEC,VVTI,DVVT and etc)
Its lets you build, from scratch, completely new ignition timing maps and fuel maps and cam angle maps and other variable maps(like vvti dvvt vtec etc) with current engine modification.Optimal for your boosted application so you can run a safer tune that will make more power.
Thats the big different between performance remap and emanage piggyback.
One last question before i am pulled in.
Does the price include before and after dyno results?
At least, it's better then 'butt' dyno and easier to convince your customers.
thank u for the info..
sorry have to ask many question..
just need to be really sure..
thanks..
Its ok.Its my responsibility to give the right fact and the info to the client.welcome.
so u do include a dyno to proof results rite ? auto will work just fine ?
Promotion.Only for 2 first perodua myvi will get dyno test session after install this remap performance chip.Auto 100% fine.Already install to auto myvi.Fast and aggresive to reach 7000rpm redline.
nice price n items bro..
i wanna ask..can it increase topspeed and acceleration dramatically?.my myvi top is 175 so far, and 0-100kmh in 10s..mod ofcoz..:P
and for the dyno, how much it is?
thx..
can can reach top speed more than 175 may be 185 or 190 can test it first.Depend of your engine.If your engine already run 100,000km above sure so much carbon deposit at cylinder head area.Anything we can test install and run a few kilometer first.Take a look.I cant prove it here.
hi boss,
i interested bout this
before remap the chip
can my car dyno 1st for free to know the horse power/torque?
cause im not ori myvi dy...
hi, may i know the myvi that came for the remap is which year myvi? as there are different between 2008 and 2006...
hi,,both 2006 and 2008 can use.same ecu.
---------- Post added at 10:57 AM ---------- 6 hour anti-bump limit - Previous post was at 10:56 AM ----------
hi boss,can..
