oil leaking..
kompak
Silver State
my car is leaking...
what happened aa actually
i have to keep on filling the engine oil
since it's draining quite fast...but no so fast laa
gitu2 laa....
is it the oil sump dah rosak ker???
coz ada kemek skit at the oil sump tuh...ker oil pan....
entah laa apa ke namanya...
this is the pic...
http://i7.photobucket.com/albums/y278/kompak/kete%20saya/RIMG0339.jpg
haa..at that area laa...
this time i just parked the car...
oledi leaking...cepatnya
donno laa....
help me aa
tq
May be u need to check with oil sum gasket. Had the same problem before and it's fixed after changed with new one. :)
jack dulu kereta... then see where the leaking came from.... after that baru pergi beli part...
only change the oil sump gasket ek....
even if the oil sump have little kemek....
apa part have to buy???
Depends on how bad the dented area is..... i suggest u replace it since it might change the original characteristic of ur oil flow in the sump......n if u r on tight budget, just replace the gasket... it would be just fine...
check the oil sump nut .. if need be, put white tape before sealing the nut ..
ok...
i'll change the gasket first
if still leaking..
i'll change the oil sump laa
how much the price aaa...
chop shop & new one
u can see there are too many engine oil on the floor...
i've just changed the oil pan complete assembly....so far no leaking..
so let's see tomolo how's the condition....
will let u guys know if there's any leaking again...
hey pal... i think u should check is there any oil leak from your block gasket... becoz if the oil pan gasket leak it wont leak till the exhaust there too...
just my 2 cents..
just my 2 cents..
if oil pam gasket leaking..exhaust also kena...
but..it's depends on how serious there r...
if major leaking..sure kena... :D
correct me if wrong.. :D
just my 2 cents..
agreed.. this is not oil pan issue.. u can see the leakage is from the upper side.. check your block gasket .. ther emust be a leakage from there somehow that oil flowing down to your down header..
my 2 cents
