sub can run full range mah...nonit xover...
n wat u mean by wait ur amp spoil 1st?
y wanna do tat?
u can try getting electronic xover where u can adjust the freq of
ur subwofer loh...
my sub is trying to play high frequency signal that cause my sub to produce weird sound.......i dont want to buy a electronic crossover coz i only hav 1 amp which is the sub's amp in my car and i dun plan to buy another amp so i think its a bit wasteful......i hope i can get a passive crossover with low pass to put with my sub to filter the high frequency.....you guys know where to get 1???ad how much is it?????
would it be better to install a cheap 2nd electronic crossover compare to a new passive crossover???
i think u need a large coil somewhere around 500 to 800 microfarads (depends what u can find in the market) for a -12db high pass filter 4 ohm at around 50-80 Hz, something like that lah, im not so sure myself........
kepada sesiapa yg pakar boleh membantu saya untuk memasang vacuum meter pada tiara saya inginkan pertolongan anda. Sambungan untuk tube vacuum yang saya maksudkan. terima kasih.
