Need help superchager in vios.
maxken
I HAVE A TOYOTA VIOS '04 WANT TO FIT IN A SUPERCHAGER .BUT I HAVE A FRIEND WORK IN WORK SHOP , HE SAID VIOS ENGINE CON-ROD WAS SO THIN AND CAN'T STAND SO MUCH OF BOOST. ANY IDEA?:hmmmm::confused:
no problem, can buy custom forged thick conrods
not so expensive, maybe around 3k-4k ? hihihihihi
if u get more boost but dun expend more cost ,u can low down compression ratio with 1.5mm metal head gasket X 2pcs( 1bar boost):proud:
at the end of the day the money spent and satisfaction level will it be at par?
Hi bro, by lowering the compression and boost 1bar, can this eliminate the fragile problem?:hmmmm:
I don't think so right? It has to be changed... :love:
if u have suit compression ratio of boost is noting problem to ur engine, my friend workshop get vios n bolt on turbo for 1.2bar on stock engine by 2 layer mental head gasket (the workshop name is REV enterprise at kedah alor star)
if want safely n durable on stock engine i recommence get low boost around 0.4bar - 0.6bar enough!
high boost for plp dont care about all !!!
