MX5 rear axle
reintel
after all the hard work, R&D, money,sweat, and blood on the car, we finally manage to build 1 drag machine but we totally for got the axle! the ring and pinion broke into pieces!!!............. the housing is still good and the driveshaft is usable.
my question is where can we do the custom ring and pinion? location is no problem but preferably contactable and reputable.
2nd question, is there any model car we could replace the ring and pinion but it has to be stronger unit and able to hold more torque.
Tq.
Just a thought, how about instead of upgrading the ring and pinion. How about change changing the whole diff to say something bigger. Then adapt the diff to the subframe and fabricate your own drive shaft.
Just my 2cents.....
good suggestion. however, wat model can we use? if we were to use diff model, not only the driveshaft we had to do custom made, but also the long shaft and this for sure will weaken the whole drive system. we r now only using semi slick. and the new slick tyre has just arrive. judging by the amount of torque made from the engine, we need more reliable setting.
Just a thought. Have u tried posting this question in specific MX5 forum rather than in a feel good talk cock sing song forum?
I'm sure a specific MX5 forum would have more enthusiasts that might be able to give a reasonable suggestion.
Well another idea u could try is to run a higher final drive or numerically lower diff.
That way with lesser teeths the ring and pinion would have a bigger contact area and the gears would be stronger.
Just my 2 cents.
Tq.
MX5 drag machine, congrats:regular_smile: what engine you using ?
engine still standard exept for the internals. the machine belongs to my fren but we all combine forces to mod the car.
u can check out the pict below. but the latest one is not in yet.
http://xceleration.dynu.com/forums/index.php?showtopic=560&st=160
