Mitsubishi Air Flow Sensor
oyw
Good day guys,
My engine: VR-4 RS 4G63T, ECU 5808.
My current AFM is having problem and decided to change it. But as you guys know that now adays it is very hard to get a VR-4 AFM in the marketplace (VR4 AFM almost pupus ady).
I would to ask whether can I plug and play Evo 609 AFM into my VR-4 RS without changing ECU?
or run the engine with 4G93 AFM? (I heard some people saying that need to modify the AFM wiring + socket)
Which AFM is better for VR-4 RS?
Evo 609 AFM or 4G93 AFM? (where can i get it? roughly how much for 2nd hand?)
I totally :confused:confused about it. Can anyone/sifu/expert explain?
Thank you,
Warmest regards.
plug n play definitely cannot. must change socket (15mins kacuk wire job) n also the airflow hose. no need to change ecu but best if tuned to compensate the difference in airflow value (if i'm not mistaken voltage kot) with safc minimum.
4g93 afm no use. use 609 n u will feel the difference...
Thanks alot bro! wah... 15mins kacuk wire+hose... so easy only arrr?
bro, do u have any idea marketplace selling 2nd hand 609 AFM how much? and where can I get it? cause I need it asap. Thanks for sharing... tq tq...
here got one rm200
nett 0172670526 yong
Bump: here got picture:smokin:
Bump: with samco hose
here got one rm200
Hi bro, where is ur location? RM200 AFM + wiring as well? Got problem kah the AFM? Actually I really scare of online purchasing.
This is because my current VR4 AFM also bought through online forum. But the sohai seller con me, the AFM got problem. When i get back to him, he ignore my call and pm. I have financial problem ady, yet kena con. Really disappointed with the seller la. So now I decided to get another one.
Bro Criss Yong, pls don't take my words so seriously, I'm not doubting on ur item. But just expressing my bad experienced. I sudah pokai, so need to spend my $$$ wisely. Hope u understand. CHEERS.
just go to kedai potong, buy complete with socket (ask for socket that has around 2-3cm of wires) and also the airflow hose if ur not using stainless steel pipe. if got problem sure can ask for exchange...
Yes bro... U are right.
Well millions of thanks to u guys...
I just talk to my mechanic and he will get a 609 AFM for me. But he is unsure about modify the wiring (kacuk/kahwin wire) because he never did this before.
So how to kacuk/kahwin the wire? can anyone here explain into more detail? Tq Tq:adore::adore::adore::adore:
1. Do I need to kacuk/kahwin certain wire at ECU?
2. or only kacuk/kahwin certain wire at engine bay AFM there?
Really need advise and opinions from u guys....:adore:
only need to kacuk at the airflow sensor socket only. no need to kacuk at ecu but it would be great to install safc...
check this out
http://www.vfaq.com/mods/2GMAF-1G.html
1g=vr4
2g=evo
good luck bro.
p/s credits to vfaq.com for installation guide.
only need to kacuk at the airflow sensor socket only. no need to kacuk at ecu but it would be great to install safc...:beer::beer:
check this out
1g=vr4
2g=evo
good luck bro.
bro khoyos, thank you banyak2... thanks for your useful information! I'll print it and show it to my mechanic... really owed u a big one bro...
Where are you from? mayb we can go for teh tarikkk... lol... :tee:
Anyway... thanks alot bro... :shakehands:
Bump:
check this out
1g=vr4
2g=evo
good luck bro.
Bump: another question bro,
which option will be better for 609 AFM?
1. S-AFC? or
2.e-manage+dyno?
my car is still stock VR4 and I don't have much budget for gadget... :smokin:
let me help u..
mr khoyos from shah alam..
still virgin..and he is my good old fren 2..:adore::biggrin:
Bump: let me help u..
if less budget safc enough la, but make sure tuned by proper tuner with wideband sensor. nowadays even kancil tune on dyno but if wanna save, tune on the road also ok. emanage more function, depends on budget.
hampeh ko lypan, jgn la ckp aku virgin, nanti kantoi kat kenggeru:thefinger:
hey guys, thanks to you all...
especially special thanks to u bro khoyos... ur guideline is loud and clear.
my VR4 successfully installed 609 AFM :biggrin:
but there is one problem... my "check engine" light is blinking frequently
my mechanic said the 609 AFM cause the "check engine" light blink.
however, my car still can boost smoothly without any problem after installed the 609 AFM.
my very last question, should I bother the "check engine" light? :hmmmm2:
as my mechanic said, alot of 609 AFM will go crazy and cause the "check engine" light.
again, I need ur advise and opinions :adore:
Thank you,
Regards.
ermm... my humble opinion.. if possible try another 'healthy' 609 AFM ....
:hmmmm:
Thank you,
Regards.
Something is not right bro..it should not blink..check back the wiring or get another 609 AFM..borrow ur frens 609 test first la
check back ur wiring, maybe got lose, next time if ur re-wiring anything, its best to get a heat shrink tube, so that the wires all stay input, last time my barometric wire came loose, and the check engine light kept blinking...
yo guys...
confirmed my 609 AFM got problem... my mechanic said the sensor got problem...
maybe the AFM left at chop shop for a long period ady so turn up cacat... :confused:
so will change another AFM... until the problem solve... hehe :biggrin:
anyway thanks u guys!
thanks for your advise... opinions... idea... really help me alot...
ALIGATO!
CHEERS! :beer:
Heat shirk tube only make your wiring neater. It doesn't prevent the wiring copper from beating attack by heat and oxygen. The actual way of doing it is to solder the connection. It'll last you forever.
yo guys...
ALIGATO!
CHEERS! :beer:
Good to hear that u've diagnose the problem. Good luck.
T
Replies
14
Views
1K
T
