Megasquirt
Dear All,
I bought my MS kit from DIY Autotune can some please verify if my car will be able to start? Is there already a base map in the microprocessor/chip?
Trying to contact cipan but to no avail so if anyone can forward me a phone number (or should Cipan see this message) pls do so.
Thanks.
of cos there is no base map
how will the ms know wht car r u running
wht kind of setup r u running
wht kind of firing system r u running
:D
Dear All,
Thanks.
There is no "base" map in the megasquirt when u buy it.
First you should make MS compatible with your engine. MS can work on all kinds of gasoline engines; so first u gotta see what ignition and fueling system are u gonna use.
Than u burn the newest code in your MS, and than u need to configure everything in your MegaTune software to work with your engine and all the sensors. Then u start making your first ignition and fuel maps...
Quite complicated if you don't understand the basics of your engine, electronics, fuel and ignition...
It would be best for you to contact Cipan, he can make all of this for you.
What engine do u plan on Megasquirting?
Initially when I came here only because I could not locate Cipan, which I have now. The engine I am Megasquirting is a VW KR engine. I am currently at a stage where the hardwear is being installed, the rad, alternator and the a few more bits and pieces. Cipan has already given me a base map just to get the car started and then the fun part begins.....:hmmmm: Thanks for all your helps. Cheers
VW KR you say... Definitely good choice, we always use KR or the KR camshafts on PL engine.
Most cars on Croatian roads are VW Golfs.
Here's a picture when I was building my friends KR; I removed the K-Jetronic mechanical injection and made it electronically fuel injected:
http://img215.imageshack.us/img215/4360/dsc01874largeiw4.th.jpg
Good luck with your project!
Just want to say thanks to all that has helped me in the process of going MS and above all a BIG shout to Cipan for his professionalism and patience.... terima kasih.
11.05.08 Cipan saves the day again......
guys i'm wondering where u guys normally bought the MS from??? Mr.Cipan or Diyautotune.com?
coz i'm still considering which MS to go for???
i got a bolt on turbo engine at the moment...
may i know if i just get the MS I or II complete set from the website isit sufficient enough or i need other kit as well???
You can choose to buy from DIYautotune. But You make sure you know how to fix it la. Buy from Cipan much simpler , one package cover all.
hehe :) nice meeting u the other day
if buy from the website you guys buy the complete package or what???
i plan to buy from that website and let Cipan fix...but scare he screw me later haha
