Logged in as: GTIEVO3 ( Log Out ) My Controls :: 0 New Messages :: View New Posts :: My Assistant
Advertisement
Home » Zerotohundred.com Forums » Cars » Forced Induction
Malfunctioning Fuel Pump, for Evo3
Attach New Poll ::Track this topic :: Email this topic :: Print this topic
GTIEVO3 Posted: Oct 27 2004, 12:07
Advanced Member
Group: Members
Was wondering how can u tell that your fuel pump is about to "kaput". How much does it cost for an Evo 3 fuel pump and where could i get it from? Another thing my car jerks at high rpm esp 6.5k and misfires quite often. Isit bcoz of spark plugs and cable or insufficient fuel? FYI im still using those items from the half cut...hope sifus in ZTH could help me out. Thanks in advance
evo3 Posted: Oct 27 2004, 12:12
Advanced Member
Group: Members
yalor....i also wan to know whether how can we tell the fuel pump gonna Kaput or not....
GTIEVO3: helo....i still have the same problem...i change the spark plugs, cables, fuel filter....problem still the same....
can ne one help me on this too, mine also will jerk during high rpm/when the turbo start to kick in..but the problem is there is no BACKFIRE....for example...i tekan, boost come...after a certain period of time, it jerk, BOV open, boost drop, the feeling is like there is not fuel coming in to the combustion chamber....
____________________
TrUst G()d but D()n't F()RgEt Ur UmBReLLa
zoey Posted: Oct 27 2004, 12:45
Member
Group: Members
u can put a small gauge near the fuel filter or use the fuel regulator gauge to check if the pressure is weak. the best alternative is to have a external backup fuel pump or even run parrallel with a switch control.
abt the jerking thing, based on personal experience its running on lean. probably the rest can share some stories.
GTIEVO3 Posted: Oct 27 2004, 13:13
Advanced Member
Group: Members
QUOTE (evo3 @ Oct 27 2004, 12:12 )
Hello there eVo3, problem still persists after u changed all that? i tot of changing the plugs and cables first. Btw isit true that misfires means that you engine is running rich?
evo3 Posted: Oct 27 2004, 13:37
Advanced Member
Group: Members
yup..that wat my friend say cos the unburn fuel will cause the backfire.....
cypress8,
so u mean that if the head of the spark plug is whitish the engine is running to lean?
