Just tc'ed my spectra. Help needed!
toms69
Asia
Using td04, wif intercooler and bov etc..the problem is that at 1-3 gear..i dint get any boost...only when at 3rd gear, and when speed is near to 100kph,then the boost slowly creeps up..at 4th gear i dint get any boost..and at 5th >130kph, then it's at 0.5..
so what is the problem? is it suppose to be like dis? i drove my fren's rex before and it wasnt like dis..
mebbe becos ive not fixed any ems? im looking for one which is compatible e.g microtec but frm wat i was told..it cant be used?
already in plans are ems, injectors and bc...have yet to find injectors that are compatible too ;)
any help is appreciated...tanx!
call - 0122125840, look for Toby.. tell him Bryan-Supra introduced...
Another one to the slaughter house
"....Bring me your daughter...Bring me your daughter....to the SLAUUUUUGHTER!!!.....LET HER GO!! LET HER GO!! LET HER GOOOOoo!!" (Iron Maiden, 1992)
ahahahahah............ he wanted a solution... dat number wil llead him to the best solution possible... but... at a price
Look for Joshua from Millenium Motorsport. . . .
hehehe..wat kind of price :)
turbo boost lag
Hi Toms69,
Pls bear in mind, I'm no expert on turbocharging.
But what i know and also common sense tells me (based on ur info)....
1>ur turbine is too big. Turbos rely on exhaust gas to spin the turbine...so if ur engine cc too small to create boost (at ur desired rpm) then u need a smaller turbine. Or use back that turbo and spin ur engine at higher rpm. means u need to lighten ur engine internals, free flow exhaust, harder valve springs etc etc. basically building a race engine. if thats what u want
2>intercooler too big/ inefficient. too much pressure drop.
3>exhaust manifold and/or intake piping too big. Bigger not necessarily better. Cos bigger piping although has the ability to flow more, u lose out on the velocity/speed of air in piping.
someone pls correct me if u think im wrong.........
my 2c
140dB
btw, may i know where u did up ur bolt on turbo?
For xzos, its already 1.34", operated rear muffler, open cat and free flow centre. td04 is one of the smallest turbo that i noe off..its more to fast to spool, fast to finish :)..for the intercooler, its abt 25cm long x 07cm thick..
haiz..headache oredi..heheheeh..
140dB said:
Hi Toms69,
my 2c
140dB
td 04 stock rex turbo
Hi,
may i know the engine capacity of the rex compared to your spectra?
if urs smaller, then its no surprise the rex will create more boost at same rpm.........
also, may i know where u bolt on ur turbo?
TIA,
140dB
a little mo specific please
Hi Toms69,
I am currently working in JB semi permanent. So i have the option to bolt on here in JB or when i go back to KL side.....
May I know the name of the workshop?
TIA,
140dB
140dB said:
Hi Toms69,
TIA,
140dB
u got pm
How's ur turbo now? Still lagging? Try remove ur intercooler n see... How's the turbo manifold done? Maybe the construction lags ur boost..
isnt 1.34 inch really small? a lot or turbo cars are using 2.5 inch.
i think he was referring to the manifold/extractor piping.
yea i agree 1.34" too small for turbo exhaust piping....
140dB
