Jerking when full throtlle
pathfinder
Hi
The engine is VR4 Cyclone
Cyclone is 200bhp right?
The RS 240 bhp and written Cyclone ECI Multi right ?
All is standard, except E3 intrcooler, Nissan RB fuel pump and 3" piping exhaust
When speeding, at high RPM there's sudden jerking and kind a brrp brrrp brrrp sound. (sorry..dunno how to xplain).
What the possible cause and what should i look for?
Is it bcos of standard ECU? No performance chip upgrade yet.
Is it bcos of fuel supply system ? Too rich or to lean...?
Is it bcos of airflow sensor?
Also need to know VR4 injectors cc...
Forgot everything about VR4 stuff. Helping a fren sorting out his wira VR4
thank u
vr-4 injector is 450cc.u can check ur plug,tr unit,plug cable n ur fuel pump.
it is either not enough fuel or incorrect heat range spark plugs is used.
another to check is the plug cables.
try hks iridium racing plug with side gapping?
prepare 2-3 brands like denso, ngk and hks coz each of them having different ability
any misfiring when it jerks?..
a friend has this kinda prob before and it was fuel supply related...
yeaps u guys are right
truth is , there are many possibilities
u need a mech to troubleshoot
fueling , ignition system , bov
these are the possibilities
Hi si fu there.... Can further explain why the BOV can cause the car jerking?
Currently my BOT also having the same problem. When i try to press a little harder on the throttle, the car start jerking. My car last time was having ignition coil burnt problem. COuld it be the ignition coil cause this thing happened? On the other hand, when i boosting, sometime my BOV will release the compressed air but sometime it will rebounce back to the turbo :-s. THis will cause jerking as well??
Fuel supply...Put fuel regulator will solve it..
Or SAFC also can...
Mine also the same previously...
Air that going to filter not enough also can face such problem...
Good Luck...
but I'm using walbro fuel pump, the fuel pressure should be enough right?
last time, changed fuel pump several times, in the end, found that my stock fuel regulator was the culprit - it clogged. go shoot with the airgun.
fuel not enough or ur injectors kaput...my fren had da same prob...or may b...ur ekzos manifold...crack oso like tat...
