Iswara Rear Disk Brake
pentavalen
HALLU GUYS
i drive iswara a/b, i wanna place the rear disk brake at my car.
so.. which one of disk brake must i use..
some body told me using mirage disk brake...
it's that true?
yes its true & its rare & if got one its expensive - cost u around 7-800
FYI the drums on iswara 1.3 are enuff bro, unless u convert ur engine
upgrade the front disc pad, brake servo etc first ! front are far more important
there is a STICKY thread in proton/perodua about this topic, pls check it there. all questions and answers are there including pics.
u can use mirage or vr4 pcd 114.3.. itll cos u around 350-450 with installation...
not 2 4get when u buy the rear brake pls ask then for hand brake kabel as well..
all the best bro
plug and play rear disc brake for saga iswara is vr4 and mirage only lor...
others need to mod ler....
for example that STICKY thread uncle fred mentioned, he uses putra rear disc.... not really plug and play la... coz u will be running on different PCD for front and rear....
rear disc brake only help alot during higher speed braking... at lower speed, it works jz as same as drum brakes.... if u wanna improve ur braking performance, upgrade brake pump and servo first....
Bro,
go search for VR4(have to mod a bit) or Mirage(pnp) front with servo, super grip & enough for your stopping power, will cost u around rm250-350 depends on conditions
minimum wheel size are 14, couse the set is BIG, ventilated & cross drilled(if u lucky)
good luck
SM4 servor would be the best if ur thinking to change ur servo...
super touring rear disc fits perfectly...vr4 and mirage need to mod bracket...for the caliper...
yeap.. n sumtimes caliper could cos u 100 ++ for a pair
