i'm having problem with my gen 2
batcha2020
i just bought the car ... its a 2nd one .. everything was ok but suddenly the gear changes every time i come down a slop and press my brake ... thats freaking strange ... the gear drops then wen i accelerate a bit then it changes back to the top gear ... the best part is wen i'm driving in a normal road nothing happens but wen on a slope gone .... any one out there .. any gen 2 sifu .. pls help me ... i'm not familiar with campro concept ....
i think u need to service your valve body....
its an auto tranny i presume...
its an auto ... but why does the gear shift up and then down .....
batcha2020,
if i'm not wrong it is the system of the automatic gearbox..
during a down slope if u apply brake then the gear system will shift the gear to lower gear in order to lower the speed of car.. as in trying to help u slow it down..
waja 1.6 year make 2000 has this system where i think it apply to yours as well..
i dono what the system is called but somehow it got the same base concept as Honda Grade Logic System.. check it out & u will know the downshift & y upshift once u apply gas..
it's nothing wrong with your car engine, it's just the system function doing the job for safety purpose..
blank just make things easier...
the system called Invecs II..
here some of the description..
"INVECS would, for example, downshift to increase engine braking while travelling downhill, or similarly automate transmission processes which were previously only controlled manually by the driver"
if there is any mech told u it is gearbox faulty/"kong".. go back there & kick his ***
i driving a gen2... theres nothing wrong wif ur gearbox.... the system help to slow down during going down slop... drive for some time u will get use wif it
