how to setting fuel regulator??
wei, i have problem with this stuff recently. i adjust around 32psi. but why sometimes engine feel like going off?
one more thing, there is fuel coming out from the vacuum connection of that fuel reg. is that normal ah?
NOT NORMAL AT ALL!!
Are you sure that it's fuel? There should be the dry part of the regulator. Get it checked..
i think of install oso......but now......take a look 1st.... :(
i tot after install will save fuel & power increase.... :(
its actually to add more fuel pressure to support your mod .. definately not fuel saving so much..
can lower the pressure.. but affraid engine kaboom.. if not enuf fuel..
u want save fuel try AFC.. mebi that will help..
mind to explain more bout AFC....???? :)
try this link on apexi safc.. :)
http://www.apexi-usa.com/electronics_safc.asp
Originally posted by drexchan+Feb 25 2005, 03:35 -->
QUOTE (drexchan @ Feb 25 2005, 03:35 )
--QuoteBegin-masvidal
@Feb 23 2005, 00:10
NOT NORMAL AT ALL!!
Are you sure that it's fuel? There should be the dry part of the regulator. Get it checked.. [/b][/quote]
ya.....i wonder also lah. so much fuel lah, need to shake it until all the fuel gone. maybe the diaphrame bocor already. can this stuff be fix ah?
Originally posted by masvidal+Feb 25 2005, 20:49 -->
QUOTE (masvidal @ Feb 25 2005, 20:49 )
@Feb 23 2005, 00:10
NOT NORMAL AT ALL!!
ya.....i wonder also lah. so much fuel lah, need to shake it until all the fuel gone. maybe the diaphrame bocor already. can this stuff be fix ah? [/b][/quote]
no.. contact the seller and change it.
