thanks melta..i read the wiring diagram of pivot speed meterv which provide speed limiter remover, however it was't stated that it is compatible with 4g93t..anyone hv used it?
1st my car was running out of battery, after checked by mechanic, finally found out is faulty of alternator. But the problem is I can't find any recon alternator here. Thus normally what will you do if your...
Hi ALL.
Just need some help as to the mileage that the car needs to clock before it needs to change the timing belt. Is it true that the idling speed during traffic jams must be taken into account too.
What are the...
