I3en_I3en said:sifu,
my car is a kancil L2,now boosting the ori boost 0.7+-,can i adjust the boost without using those expensive controler electric and screw type~~~
thanks`
thanks`
like tis cannot change back the original boost right???heefmy said:the actuator just knock a bit inside then u can get higher boost. my fren do it. free n get higher boost....haha.
but u have to go my fren shop lo....
what is orifice in chinese???got picture???huakenny said:u can use 'Orifice'...some smal part using in motorcycle carburetor...
u put it inside the hose at actuator there....increase ur boost....how high the boost is depends on the size of orifice u sing...
im using it now...get it bout rm5 wit mech instal for me...boost at 0.9-10bar now...okie lo....cheap
I3en_I3en said:what is orifice in chinese???got picture???
so that thing can buy at motorcycle workshop right???
the orifice bigger than the boost will higher???
bro~BlackMafia said:one more thing u can use is ... "tulang ikan" they call it ...
this one is use for aquarium (sorry if wrong spell) ... u can open and close it for control ur boost ...
the is cheap also ... around few buck ...
i'm using it now :)
I3en_I3en said:bro~
got picture mar???
dunno wat is tulang ikan~~~
my dad aquarium only got a dive pump and a filter box only~~~
i'm using it now :)
buy at fish shop??????huakenny said:i show u the photo..should be rm5 only..around tat la..
http://i17.photobucket.com/albums/b95/huakenny/fishtank.jpg
I3en_I3en said:buy at fish shop??????
how to install it???
boost meter have liao~now the boost is 0.7+-huakenny said:can get at fish shop
u need a boost meter to monitor ur boost level
ask someone tat familiar wit turbo to do for u...dun play play..later overboost..KABOOOM..................lolz
I3en_I3en said:boost meter have liao~now the boost is 0.7+-
go fish shop how to say???in chinese
later i say i want use for "deer" he kick me out~~~
L2~~~~~~huakenny said:erm...y not save the photo i upload tat one to ur handphone...then u can show to the fish shop boss....i oso duno wat it called...lol
0.7bar u may set it to 0.95bar like tat...coz if stock ecu mostly suport 1.0bar only...wat car?
got 3 valve on tulang ikan~~~BlackMafia said:ermm ... not sure what the name for it ...
i just know it as "tulang ikan" ... all item i just got from my pomen ...
bout the boost ... yups .... it's not very stable ... bust it still work as boost ctrl ...
just need to adjust it slowly ... for make sure not over boost ...
if u close it ... then ur boost will standart ... if u open it ... ur boost will more ...
i'm join the "tulang ikan" hose from the actuartor hose ... just cut it and join it at "tulang ikan" ...
but need to check wich hole is for imcoming and out going ..., :)
