any expertist can brief me why people use hi cam to increase speed? how does it work? what are different with normal cam?
its very technical, try reading "how engine works" first at www.howstuffworks.com
for high cam or performance cam, the degree of the "water drop shaped" thingy the moves the valves at the camshaft is different from stock. different degree gives different loop time. longer open loop time will give u more air thus more fuel is mixed thus better combustion = better power.
correct me if im wrong.
Hi cam are cams that are mounted at hi altitude to snap hi quality images.. They serve to increase speed by using the most advance.... Just listen to boosook.
sifoo.......Hi cam are cams that are mounted at hi altitude to snap hi quality images.. They serve to increase speed by using the most advance.... Just listen to boosook.
Hi,if i change to hi cam...do i need to install piggyback/safc as well?
anyway, hi cam will exert more stress to your valves because of the more sharp curvature on the cam profile, which might shorten the life of the stock valves.. correct, sifu sekalian?
and now gasoline price went up ad, dun use high cam lo.. use more fuel oni.. haha![]()
nope... valves are not wear n tear item... sharp curvature of the cam lobe means higher lift on valves to allow more air/fuel to go thru....
camshaft with high lift recommended to upgrade stiffer valve spring... stiffer valve spring allows valve to go up and down fast and precise so ur piston wont hit ur valve...
sifu sky,i'm using 4g13p...satria mmc batch.i plan to install hicam to increase torque.what duration do you suggest? do i have to change the valve spring as well.how much ar?:hmmmm:
the "hi" on the hi cam usually refers to the "lift" that the cam exert to make the valves move down n up.
a hi cam will make ur valve being pushed down lower to open wider , thus giving less resistance to flow.
the peak of the loob are higher for a hi cam, not neccesarily wider or fatter.
Just to make the valves open wider.
being specific on the term "hi" oni
duration and position of cam is more usual to be described by "long" or "length" and "degree"
