Help.. speed cut!!
guys..i heard that there could be some unstable idling after cutting the speed wire..some ppl actually had that problem..
L7 still using computerized power stereng ka?
i thought like L9...using oil..???
Since when RSM can set the speed cut wan? Got wan meh? Hehehez.... yeah, I heard u can cut the speed wire thingy also. I'm not driving Kancil lar... i'm driving a 4G91 Satria... mine no speed cut because digital speed sensor kong... hahaha. =)
Errr...there is a function in the Apexi RSM blue screen which allows user to by-pass the speed-cut.
If not mistaken PIVOT Rev/Speed meter also able to by-pass the speedcut.
I tot the moment u plug in your RSM already got speed cut no meh? Have to set wan ar? Hehehez... i plug mine in i never set anything... just jalan only. Kekekez... now selling mine off coz' almost kena break in my car... broke my glass but i managed to chase him away before he could steal anything. :( :( :angry: :angry:
which RSM r u talking about? the blue screen or the first model with 4 buttons??? my L9 seems to be working fine...assuming all ur wiring is correct since ur RSM has speed readings, i suggest u set the tire sizes until u get the same reading on ur speedo meter and ur rsm(but i still think this is not the reason).... if still got speed cut, then it could be ur Kelisa Speedmeter faulty...lastly, maybe ur rsm is faulty..... speed setting and reading will rely on the right pulse(P4), speed cut set at 130 for Kcars and tire setting... the rest is not important....
however, u can manually cut ur speedwire(the easy but not reliable way) but u'll have to suffer a very bad fuel consumption since ur ECU cannot read ur speed ALL the time... i tried it once, proven so u cant deny it.... L5 and above will not loose its power steering if u cut the wire, not like L2....
mind telling us ur RSM setting??? maybe u set wrongly somewhere....
stroker... i set to P4 already... readings telly with my speedo till 120.. then the RSM goes up very fast from 120 to 130... but my speedo didnt touch 130 yet. possible i must use back the L7 cluster meters? Cos i am using my kelisa cluster meters now.
