arghhh...dammmn...
when VVT is on, the pick-up seems to be slower not faster...like VVT on, the car dragging...can feel the car won't goo...
is it because of :
i) Malpassi fuel regulator, faulty...?
- i've set to 30psi with vacum on...40 psi without vacum...
ii) VVT pulley faulty...hv to be changed...n due to that...the VVT socket , dunno what to say but the VVT that connected infront of the head with socket...dunno what's the name...this thing also possibally may be faulty...
- why i say this cuz...went to this mech shop...i ask him to adjust my tuning...while diagnosihg it...make my fuel regulator go up to 38psi, then using the timing gun...the mech say...
"ur timing is too high...got no pressure..." he said...
then "ur VVT pulley and VVT connect (on the front head) is faulty...changed it first"
the question is...is that really2 the problem...just curious...
BTW...my engine sound a little bit noisy...i think becasue of the VVT...but regardless the sound...do the problem occurs above...because of question 1) or question 2)
Thank You
Sifooo...
is it because of :
Thank You
Sifooo...
