Diy Oil Catch Tank
not really DIY lar... jus drill 2 holes sumbat the connector already call OCT :lol: i saw before some that really DIY the whole thing... straight machine out the whole OCT...
Hi, i was just wondering if disabling the fresh air 'hoe' on the top
of the block will cause any significant damage to my engine, as recently
i found that the breather which is pvc piped back into the intake
just after the airflow sensor has been sucking up black oil, (maybe cuz i overfilled the crankcase a couple of times ) now i just piped the pvc pipe
down lo, so if any more oil comes thru it will just leak to the ground....
thanks..
How about using the BIG capacitor inside the air-cond unit as oil catch tank? But the capacitor must cutted in and drilled a holes to fix in the connector.
