This is what DIY detailer do when detail car engine, just clean the engine.....
This was done a while back but did not post, here are some write up and pictures.
Use DG431 Truck and Equipment wash
Just spray water to engine to wet it, spray DG431 on affected area, brush with paint brush to loosen the dirt, then hose off...
Rocker cover....Before
After
Engine side...Before
After
Alternator...Before
After
Then a few days later, was too free and was thinking what else to do. Did a little more extreme area, went and detail the boot water run off area....
This place same thing, spray water to wet, then spray DG431, this time use tooth brush to brush, areas what stains harden to remove, use cloth and finger rub, rub....
Before
After
Before
After
Thank you for viewing....
After
After
Alternator...Before
After
Before
After
Before
After
, would like to enquire the cheapest replacement for the stock turbo
