yesterday i set it with the vacum hose connected around 2.7bar. Then go test the car. but ho...i open the hood n check again...the pressure was go down around ~2bar. how come ha????:hmmmm:
then i adjust it back to 2.7bar again. tonight will try again without connect to the solenoid (direct to manifold) for the vacum hose.
it is a normal practice to set the fuel pressure without the vacuum hose connected. btw, did you properly tighten the lock nut at the adjustment screw ?
yups..i saw that also...only the part that i wondering is only around 2bar+ with vacum hose connected. that seem very low..hehhee
but if install this FPR then run away to kl for dyno tune also feel a bit waste..some more the petrol so high now..haiz..y mlc dont have dyno machine....
my evo 7 fan didnt work fast and cause the water tempreture up,it work fast in the beginning but after sometimes,it slow down.Is horrible when i facing traffic jam at KL,need to restart the car to let the fan work...
I have some pictures I would like to share and get your appetite going . So I was wondering whether anyone out here has the same desire, but just can't find one......
To all DIY hard core ZTH gang's, I just discovered a very good technique to increase Hp in my car. In office I found a 12Vdc electrical fan. the size is kind big. Fan speed is awsome, fan spinning speed is fast. So I...
