Both signal ON when door opened ???
yeongk
I don't know whether thip topics have been posted if yes please send me the address or link ...:smile:
I wanna the signal light blinking like the emegency light blinking when the door was opened.
Thanks !!!
i guess that follows the alarm... once door open, double signal lights on... can cehck it with alarm shop.
we oso donno where is de cable running in yur car leh... :biggrin: :tongue:
don wory, everything is inside de fuse console, if u know where yur car fuse console located, u can get de job done, make sure take yur time 2 trace de wiring, n try it b4 u go further wiring installation.
any problem juz come back 2 us, send 2 shop is depend how they goin 2 "chop" U :biggrin: happy DIY
howiechoo,
Are you have a diagram how to connect the wiring to the delay .,.,., so make me easier to DIY ...
And what material i need.
- 12v delay (1pcs)
- wire
- Times to trace the door switch and the double signal switch ....
- or what else .,.,.
it's like this, i think most car are using positive signal to activate the double signal relay(dun use orange wire),but if ur car are using negative. then dun use the blue color wire)
i forgot the relay pin number..someone can help me to add..thanks
Thanks !!! so which delay i should use .,.,. the 4 pin one should be enought right ?
- 1 for door switch
- 1 for door switch
- 1 for incoming 12v
- 1 for ground
- 1 for signal light
Carrera said:
yeongk,
after trace it..let me know ok? will goto find you and need ur help. Ha ha.
no problem i will try out first then let's you know it working or not ...:smile:
sorry,,,forge tto mention there is a diod at the door switch wire there...u should notice it...got a red line at there....
purpose for this wire is to prevent the signal light turn on when u turn on ur room light..
hope u understand the diagram..
actually i not sure need the diod or not, but it's better to have it...
sory 2get interupt, i attach a diagram 4yur reference,think dis wil gv u more understanding while wiring, take note dat de door switch wiring n room light wiring may not b same, it can b trigger by relay too, U hv 2 double check b4 de diode is add on, happy DIY :biggrin:
Thanks to provide the diagram .,.,. i will go to electrical shop to get the item first.
- 12v delay
- Diode
- Wire
- and times to trace the wire.
Thanks to every one ,.,., :)
Hi,
After go through the diagram .... i wonder can i just trap 1 wiring from door switch to the double signal light so when the door was opened then the signal light will blinking ,.,. no need delay in place.
yes or no, stil depends how comfortable U r :biggrin: if not u juz try for a short period wifout adding relay, if nothing goes wrong, juz use as it is, but de diode is a MUST hv item :smile:
erm, door switch are negative current, while ur signal is using positive current to activate the relay for double signal(most car)...so if u tab it like this, when u turn on double signal and open ur door, minor with fuse break or major with double signal circuit burn.
Wah !!! :eek: like that better put delay and diode leh .,.,.,. :smile:
Thanks !!!
