aiks.. stated there 10k rpm oni?
apexivafc04 said:Almost dont know what to say, anyway thanks alot all sifus!!
Yes, i heard that aerospeed adj cam pulley are inaccurate. Is using the ctr cams make ur car idle rough? What about the ignition timing setting? Stock is 16 degree.
When i first purchase the halfcut there is no rev limit. That mean there is no fuel cut, with the ctr cam and valve spring what rpm limit should i rev to before gear shifting?
Can i change the crankpulley to more lighter one.
Thanks and cheers!:regular_smile:
hattech-v said:shiro,
cam lift is same, only duration b16b higher than b18c...
1. ITR/CTR (Chilled Cast Cores)
- STOCK 1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
- STOCK CTR and 2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
hattech-v said:then 13mm is more than JUN 3 lift wooo... jun only 12.5..
akuma said:shiro,
"b16A head with B16B cams have really tight tolerances"---->u sed dis wat?so if a B16A head is similiar w a B16B head,in terms of d height @ least,so shud haf no problem wat?
