airtrek engine replacement to evo 5 engine
just ensure u have the AP, all relevant documents from your fren in order for your engine to get endorsed.
Bro xxx475475, what he means is the import permit. Is your car locally imported new by USF or reconditioned JDM unit from Japan? No issues if it's from USF but if recond unit, please make sure you got a copy of the AP. ELse custom come chasing after you on the unpaid tax!
Please also share pictures of the progress (if you do visit the workshop). Interesting to know and hey,
WELCOME TO ZTH-MAC!
The 'heaven and earth' difference will only be obvious if the engine is complete ie. turbo, intake manifold, intercooler, injectors, ECU mapping etc. I think by the engine 'lantai' alone, you still get improvement but not that drastic.
---------- Post added at 08:24 AM ---------- 6 hour anti-bump limit - Previous post was at 08:23 AM ----------
Bro xxx475475, I will advise you to top up a bit more and upgrade the whole complete engine to Evo5, you won't regret and will be smiling ear to ear when you compare to stock Airtreks.
with same parameter forged piston can take more pressure compare to normal cast.very big diff in term of high boosting...
Agree with high pressure but I am trying to say literally with same hardware u ain't going any where. Besides there's no point to over boost the stock turbo.
I tried 1.8. Not 2 bar yet but I saw someone posted 2.3 on TD04. Dunno what's the point.
Honestly anything above 1.3 for Td04 is pointless. It's not gonna generate anymore power. With Td05, u can still hit above 2.
that 2.3 bar guy should have get a garrett turbo such as AR 50 instead to get high torque.. to be honest i actually like the stock TD04 power curve but the power above 5500 rpm is just so sad.. if only there's a way to overcome this.. maybe the TD04 16g can overcome this?
There's a solution actually. U get power above 5000 n td05 too.
2.4L stroker kit!!!!!
Around 5-5.5km/L for decent driving. If you're on heat, it goes below 5.
I initially wanted to but then I even have plans to sell my car... so it was pending again.
