Sigh... yesterday night when i turn my car aircond to 20 degree it come's out hot air... if i turn to 18 degree only got cool air come out.. anyone know what is the problem??
The bypass hose for your heater could have came lose..you can have a a/c service tech to look at it. I have the same prblem after installing my alarm last month. The reason being that the technician dislodge the bypass hose and when I switch on my A/C it blew out hot air..luckily the guys that installed my alarms reconnected the bypass and everything works fine now. Most imported cars from Japan and Europe have both A/C and heater options in the car. Hope this helps
aycy,
Does that mean your car already had the hose bypassed previously and it had no problem until you installed the alarm recently?
I am also keen to know where the bypass hose is: engine bay only or linked to under the dashboard?
Err.... aycy, hope you don't mind... I also tumpang your thread on this issue.:regular_smile: want to know more since mine also got problem... hehehe...
Tool List:
Soldering Iron
Drill for mounting switch
Multimeter
Drill bits and solder
Part List:
1x 3.5mm Stereo...
