- Joined
- Dec 7, 2006
- Messages
- 579
- Points
- 1,518
hi itz me the U/C again...............now v a problem dat read:
the rear power window and central lock, oso rear side is totally out of order....when i 1st bought the car, 2 years bek, the rear power window is still in good condition, after a year so, sometimes it cant be controlled....(sometimes when i unwind the rear window and drive, after dat when i wanna wind it up, itz out of order......then for sumtimes.....it runs........... by the mean while the central lock is totally no problem.....it onli out of order along v the power window, simultaneously......).........i tried to change the wholke set of switch oso kenot, if i wan to unwind the rear window from the main power window control panel(driver side) oso kenot..........if i unlock the driver door's lock, onli the front passenger door was unlock but not the rear doors by right it should be unlocked either..........so i m veli confused v wut is the problem actually?????????? but not the motor anyway coz i tested it b4 v a 12v battery and the motor works........i noe that there is an I/C board in all the switches panel.......so does it matter????? or maybe izzit the wiring????? or the switch???? anyone tried dat b4???????????? SIFU HELP ME~~~~~~~~~~~~~~~~~~:cry_smile: :cry_smile: :cry_smile:
).....Its...
