4g93 wif haltech sprint500
why distributor??? ecu will give 1 ignition output only..... change to wasted spark... ecu will give 2 ignition output....
mitsu cas sensor also got home signal..... why Standart no home?? huhuhu
& select injector to sequential..... wire the injector in sequence....
sori hijack abit..........
is haltech platinum interceptor good?
compares to other piggy?
tune how much same as haltech standalone???
in perak i charge rm500for NA rm700for turbo. Platnium interceptor can controlclose loop.
interceptor tune rm300 wif wideband air/fuel ratio
im really interested with this platinum interceptor, is the mapping point same as Sprint500?
cant find platinum interceptor function and parameter in the net...can u plz explain what are the funtion available..
another Q..if we fit sprint 500 as piggyback just for af and ignition compare with platinum interceptor, which one is better?
TQ
huh can add sprint500 as piggyback ka? pls explain thanks
i tot sprint 500 is a standalone?
Can piggyback style and standalone, just pay RM3800 for installation n tuning on the dyno.it's better than platinum interceptor.
---------- Post added at 05:26 PM ---------- 6 hour anti-bump limit - Previous post was at 05:23 PM ----------
And also can make plug n play style for evo1.2.3,GSR n 93.One day set for tuning on the dyno..free base map
sprint 500 installation and tuning only how much?
